hyd. lift coupler
philip
06-21-2004 18:50:21
in regards to the coupler. it appears to have a keyway, on both shafts. but no key or remains of key. am I correct? so the pump would not be turning. and does any who know where pump rebuild kit. (gaskets, and pickup screen, filter)No filter was there. what size keyway, what type of filter was there? how much slack would the cahin have driving from the pto? For the eagle hitch, where should the third arm braket be?
1952 case sc/eagle hitch
ky,Philip, Thanks
C. Amick
06-23-2004 09:25:07
 Re: hyd. lift coupler in reply to philip, 06-21-2004 18:50:21
The coupler isn't physically attached to the two shafts. It's small. Dig around in the bottom of the housing to make sure it didn't just fall off. It's round with a rib on each side, a little larger than a quarter. As I recall, the chain is not all that tight. I'm not that familar with the eagle hitch tractors, on my 1949 model, the filter is in a metal housing on the right side of the tractor. I figure that you can still get the filter from Case/IH.
