470 info?
ball NY
06-21-2004 15:52:06
I am going to look at a 470 diesel this weekend but know little about Case tractors. Any advice on what to look for etc. Are there particular 'problems' w/ this model or was it a good model? Is there a Case specs page where I could check out the HP specs, etc. for a 470? Also, will a 470 handle a 6' bush hog? Thanks in advance. Brad
Craig
06-23-2004 21:42:17
 Re: 470 info? in reply to ball NY, 06-21-2004 15:52:06
I agree 100% with the other comments, have had my 470 for over 10 years with nary a problem. Runs like a tank. If you can knock down the weeds with a 5 or 6 foot brush hog, you can cut them with it. Only problem I had of any significance is I broke a front steering spindle once - probably had been cracked for years 'cause it just dropped out from under me one day (fortunately at low speed). At that time Case still carried it for $290, now I would probably have to cruise junk yards. But I would buy another 470 diesel in a heartbeat.
Lamont
06-22-2004 20:25:01
Buy it and you'll probably never have to work on it. Super fuel efficient and dependable. I can almost promise you'll like it. My dad has a 570 that has been used so much it has worn out two sets of the hitch balls in the 3 point and the third set is almost worn out. Unbelievable little tractors.
Roger (Mi)
06-21-2004 20:11:14
The 470 diesel will put out 40 horsepower all day long and will use about one gallon per hour. It will play with a 6' chopper. It has a number of improvements over the 430: independent PTO, an oil return to the hydraulic torque tube if the rockshaft piston leaks, etc. It's a great small tractor.
