Overheating
Kelly Hanson
06-19-2004 12:56:14
Does anyone else have problem with the 49D Case overheating?? Any suggestions would be appreciated! Thanks!
C. Amick
06-21-2004 09:53:31
 Re: Overheating in reply to Kelly Hanson, 06-19-2004 12:56:14
When you look into the top of the radiator with the tractor running, can you see the coolant circulating? If the radiator is clean, your problem may be caused by rust build up inside the engine block around the wet sleeves. You may need to try flushing out your block.
