Need help with 580CK brakes .
Rick in Marylan
06-17-2004 17:54:24
All, now that I've got the backhoe running, does anyone have suggestions about how to attack fixing the brakes ? I live on a hill so having these operational is a must. I have the service manual showing the arrangement of parts, but I suspect that there are probably "tricks" to pulling this job off successfully. Thanks in advance for any help you can provide. Also, if anyone has suggestion on a good source for brake parts (linings, etc) please pass them on. I tried posting this before but got no responses. I could really use some help here.
thanks, Rick
Roger (Mi)
06-26-2004 06:17:00
 Re: Need help with 580CK brakes . in reply to Rick in Maryland, 06-17-2004 17:54:24
The brakes are made by Bendix. They consist of a two-part band (with riveted linings) going around a two-part drum. When the brake pedal is pushed, the band tightens around the drum. As that happens, the two-part drum (with riveted linings on both sides) will expand as the three steel balls roll up ramps inside of the two-part drum. That action forcefully applies the brakes. It�s a good brake system. However, rust can render them useless.
On most Case models, the floorboards must be removed to service the brakes. Remove the brake adjustment nuts. Remove the bolts/nuts that hold the brake housings onto the transmission case. Removing the brake housings on some backhoe models can be challenging because there is backhoe attachment interference. Either remove the studs in the transmission case using jam nuts or loosen the backhoe supports to get the necessary clearance. Once the housings are removed, look for oil seal leaks. If seepage is evident, the seal/s will need to be replaced. The band that goes around the drum will come off with the brake housing. In the brake housing, there is an anchor stud and two small springs holding the band in place. Knock out the small steel plugs (Yes, the plugs can be reused.) to gain access to the springs. Find a steel rod about 8� long that can fit inside of the springs. Grind a small notch in one end of the rod. That notch will prevent the spring from slipping during removal and installation of the springs. The same tool will work for the two-part drum disassembly and assembly too. Clean out the rust! The brake surfaces where the linings make contact must shine. If not, the brakes will not work well, or they will chatter. Make sure the internal brake linkages are rust free and lubricated before reassembly. Also, remove any internal rust from the two-part drum. Any badly rusted or stretched springs must be replaced. The brake linings and springs can be purchased at any Case-IH dealer at a fair price. If you don�t have a device for removing and installing rivets, have the dealer or an automotive machine shop do it for you. Before putting the brake housing on the transmission housing, put a bead of sealer around the brake housing contact surface to prevent water from seeping into the brake assembly. When everything is reassembled, adjust the brake pedals to one-inch free travel. Good luck.
Rick in Maryland
06-27-2004 05:14:56
 Re: Re: Need help with 580CK brakes . in reply to Roger (Mi), 06-26-2004 06:17:00
Thanks Roger. That was a detailed explanation. After lubricating the brake linkages I have "some" brakes, but not much. I was doing some disassembly in preparation for the brake work ( and also painting) by removing the cab and fenders. I did notice some of the interference that you're talking about. Hope I only have to remove some bolts and not the backhoe attachment !
Esev
06-26-2004 20:18:29
Thanks Roger,
That helps out a lot.
Esev
06-18-2004 18:32:02
Hey Rick, I have been following your posts waiting for someone to respond as well. I have a 1968 580CK with 159G engine, and I am in the same situation as you. My machine is worn, but it runs good, has good hydraulics, and gets the jobs done on my place that I need it for. But NO BRAKES !!!! I just got a parts manual, and a owner's manual from e-bay, so I am studying up to get ready to tackle it. The first thing I noticed is that mine still has some adjustment left in the linkages, so I am going to try that before I do anything drastic. I have a feeling it won't be that simple though.
Good luck, Esev.
