Case 990
Chris
06-17-2004 17:36:35
I have a Case 990 with pto problem.
Cant ingage the pto while the tractor is running.
Even with clutch peddel fully depressed, it acts
like a live pto. Any ideas?
Pat T
06-17-2004 18:37:11
 Re: Case 990 in reply to Chris, 06-17-2004 17:36:35
Two things to check, first get the owner's manual and follow the directions to set clutch pedal linkage adjustment, all of it don't try to skip anything. If you're still having trouble, there is an adjustment on the three clutch pressure plate throwout levers detailed in the I&T shop manual. Elmer has posted a shortcut on this procedure before that does not require the use of feeler gauges,>Link
Hope>Link this helps.
