830 front weights
Alan Whitaker
06-17-2004 09:39:54
Got the 3x16 rollover on the tractor, and it pulls it okay, but now I need additional weights for the front end. There's one on it, but I need more. Any one have or know of some cheap front weights for a wide front 830? I know I'll get hammered on shipping..... maybe a 350 cid Chevy block wouldbe cheapest. thanks
Patrick
06-17-2004 22:56:48
 Re: 830 front weights in reply to Alan Whitaker, 06-17-2004 09:39:54
Alan, the 730 weights would indeed fit on your 830. I just have to wonder, are you adding front weight because the front wheel are actually lifting off the ground?
Alan Whitaker
06-18-2004 18:05:59
 Re: Re: 830 front weights in reply to Patrick, 06-17-2004 22:56:48
The tires only lift off the ground when I'm traveling to the field. It gives me the hebee-jebees when it does a wheely..... .....
leland
06-17-2004 19:52:28
if you don't want to pay shipping on old cast iron i don't blame you we have in the past have used tires full of concrete just put piece or 2 of 1in steel pipe for bolt holes ,orbuild a box bolt to front end if you what it on there all the time them pour it full it'cheap and works good luck
tom
06-17-2004 10:08:42
alan...i have a pair of front weights (175 pounds each) they fit on my 730...they bolt around just under the radiator screen...i dont know if they would fit a 830???
Alan Whitaker
06-18-2004 18:03:11
 Re: Re: 830 front weights in reply to tom, 06-17-2004 10:08:42
What are you asking for the weights Tom?
DKase
06-17-2004 20:18:24
730 through 1030 should be the same. 700 through 900 would fit also. I think most of the 70 series would work too. Good luck DK
Alan Whitaker
06-17-2004 15:08:06
Tom, I don'tknow either. Maybe someone in the know will know and let us know..... ..that's a lot of knows!
