Flywheel/ Pulley
Levybrat
06-17-2004 04:28:17
If i remove half of the pulley on my 1949 S is it going to affect the weight on the crankshaft or is there a separate flywheel on the S.
C. Amick
06-17-2004 08:37:58
 Re: Flywheel/ Pulley in reply to Levybrat, 06-17-2004 04:28:17
I guess you noticed that there is a pin through the crankshaft that holds the front pulley on. You will have to drive it out.
Bruce Nelson
06-17-2004 05:55:40
There is a flywheel on the engine. If you remove any rotating part that does NOT change the center of gravity of what remains you will not affect engine balance. Bruce
