SC Governor
Glenn FitzGeral
06-16-2004 20:12:57
I ran my '54 SC only briefly prior to installing the adjustable wide front end. Now that I think of it, the governor seemed pretty lazy. Is there any way of checking out the governor without the tractor running? I'd like to know before I put the radiator back on. Thanks, Glenn F.
Mycase
06-18-2004 22:02:31
 Re: SC Governor in reply to Glenn FitzGerald, 06-16-2004 20:12:57
Most lazy governors should be voted out of office! Well in this "Case" you probably have woren parts. I would take it apart and check it close for woren parts while it is easy to do so. Make sure it has the right parts and put together correctly. Best to have a good manual that shows the sequence of parts to make sure everything is correct. Good Luck!
