what year VA
jon holt
06-16-2004 20:08:32
Help!!!! My tag is missing off of my VA and I am getting ready to start getting it ready to work. I was wondering if there was any other numbers that I could look at to find the year and also possibly what series it is. The auctioneer said that it was a VA1 but I have never heard of one. I think it is the VAI because it has 24" rear tires. Thanks in advance.
Carl Raasch
06-20-2004 18:40:34
 Re: what year VA in reply to jon holt, 06-16-2004 20:08:32
Jon: On all V series tractors. Once the ID tag
is gone you have lost the serial no. The no.
above the starter on the block is an engine no.
only and not the serial no. of the tractor.
Art
06-17-2004 03:50:13
Hi Jon, You can confirm it's a VAI by looking at the front axle...All VAI's are non -ajustable wide front. Also the front axle will be heavier than a VA. A VA axle will be 1.25 thick, where a VAI will be 1.75 to 2.0 thick(from the top, looking down)It's the year thats going to be harder to pin down. They stamped a number above where the starter mounts, on the engine block. Some of them are stamped, some not....Good luck...
