racine 400
n cloyd
06-16-2004 05:13:12
where does the remote hydraulic cylinder mount on the 400s and what does the mount look like?
ncloyd
06-24-2004 17:19:47
 Re: racine 400 in reply to n cloyd, 06-16-2004 05:13:12
I should have made myself clearer----I would like to know where the remote hyd cyl storage bracket mounts and what it looks like as the parts book only lists a number for it. Thanks
Pat T
06-16-2004 16:58:59
Well, the remote cylinder would mount on whatever piece of equipment you have attached to the rear of the tractor, and uses the right hydraulic lever to operate thru the remote hose connections just below the rear of the seat. The cylinder for the eagle hitch mounts to a bracket that's sandwiched between the hydraulic housing and drawbar frame on the lower left side of the tractor, and the piston end attaches to the rockshaft yoke directly above that. The hoses are directly plumbed into the hydraulic valve body and is operated with the left hydraulic lever. The eagle hitch cylinder is a 6" stroke, however, and a regular 8" stroke cylinder will not fit.
Pat
