VAC spark coil bracket
Jerry W
06-15-2004 20:31:02
I have access to 4 VAC's (2 of mine, 1 my dad's and a neighbors') and not one seems to have what I consider an OEM coil bracket.
They all have variations of hose clamp or duct work hanging strap.
Does any body have a picture of one with some measurements so I can fabricate a couple.
Jerry
F-I-T
06-16-2004 07:30:33
 Re: VAC spark coil bracket in reply to Jerry W, 06-15-2004 20:31:02
third party image
Jerry:
I am on the road now, so I can't get you any dimensions, but this bracket, I believe is a correct VAC installation.
Frank
Joe (Wa)
06-16-2004 09:47:22
 Re: Re: VAC spark coil bracket in reply to F-I-T, 06-16-2004 07:30:33
Yeah that is it. It is 2 piece. Case cross-ref p/n for the clamp around the coil is a little fuzzy Looks like this: old p/n G46106...Discontinued...107446c2. That generally means the new part is a substitute not a duplicate. Only $5-6.
The bracket p/n G11705 that bolts the clamp to the valve cover stud is a piece of 1/16" or 1/8" flat stock with rounded corners, 5"L x 1-1/4"w. Has 3 holes, 2 for clamp and one for vl cvr stud, match holes to fit. Still avail from Case
Same setup on 300 & 400 series.
Joe
