case 530
reverend
06-15-2004 16:23:23
can't shift transmission, seems to be stuck between gears or in two gears. HELP! what can I do?
Roger (Mi)
06-17-2004 19:26:34
 Re: case 530 in reply to reverend, 06-15-2004 16:23:23
The shift rail/fork has been moved back or forward which prevents the removal of the transmission cover. Get a 1/8" x 1" x 12" flat stock. With the four bolts removed on the cover, there will be enough room to insert the above flat stock tool. Pry/move the shift rail back or forward with the above tool to the neutral position. That will allow the cover to be removed. Repair the shift fork or rail as necessary. Good luck.
reverend
06-18-2004 03:56:52
 Re: Re: case 530 in reply to Roger (Mi), 06-17-2004 19:26:34
thanks for in info, already went that route, need whole new transmission plate with forks when I got it apart one fork was broken and one rod was bent.
Steve
06-15-2004 19:26:57
We had a 530 that would do thatand what we would have to do is pull the shift cover. It is held on with four bolts. Then we had to put the gears back into the nuetral position and the shift forks too and then reassemble it. The prblem is the fact that your shift rails are getting worn you may have to build them up or replace them.
Steve
06-16-2004 06:29:13
 Re: Re: case 530 in reply to Steve, 06-15-2004 19:26:57
thanks for the info, I've tried that but can't get the cover off, didn't want to pry very much on it
