Best Case 380 tractor manual
Art Mathewson
06-14-2004 20:04:21
I just got a service manual for my case 380 from the "other" tractor site. It's a reprint and I'm not happy with it. It doesn't have a spec section, the gearbox from the clutch back is only in text... no pictures and a lot of the pictures in the other sections are not clear. $65, I thought I would get more. Other than the Original Case manual is there a good alternative?
Elmer
06-15-2004 19:18:07
 Re: Best Case 380 tractor manual in reply to Art Mathewson, 06-14-2004 20:04:21
Is your 380, a David Brown 380, or an IH 380?
Art Mathewson
06-16-2004 05:59:55
 Re: Re: Best Case 380 tractor manual in reply to Elmer , 06-15-2004 19:18:07
Its a Case 380CK. The Serial #is 885 as in David Brown. "David Brown" is cast into engine block.
Art
Elmer
06-17-2004 04:18:26
 Re: Re: Re: Best Case 380 tractor manual in reply to Art Mathewson, 06-16-2004 05:59:55
The only thing i can fix you up with is an 885 manual, pretty close to the same thing. The only thing it does not have is the shuttle transmission. I have the 380 parts book too.
Art Mathewson
06-17-2004 18:22:50
 Re: Re: Re: Re: Best Case 380 tractor manual in reply to Elmer , 06-17-2004 04:18:26
How much difference is there between the 380 and the 885 DB? I thought that the DB885 was the Ag version of the Case 380. By shuttle transmission do you mean the ability to go up (forward) from first to reverse in a straight line? Art
