Case 300 question
steve
06-14-2004 18:46:55
I am rebuilding my engine and was told the rod journals on the crankshaft were suppose to measure out to 1.937 , all of mine measured out to be about 1.936. I am going to by new bearings, the question is do I by standard bearings or .002 oversized or what.
C. Amick
06-15-2004 14:28:53
 Re: Case 300 question in reply to steve, 06-14-2004 18:46:55
Are the crankshaft journals nice and smooth? If they are, I would stick with the std. size bearings. If they are a little rough, you can probably take .001" off it with emery cloth and use the .002" over sized bearings. It's the sanding cloth that machinists use, it comes in a roll and is about 1-1/2" wide. Just cut off a piece about 12" long and grab it by each end and sand back and forth. I would also get some plasti-gauge, if you use the oversized bearings, to make sure you took enough off and things aren't too tight.
