930 lpg has water in oil
R Wyler
06-14-2004 12:48:18
I changed the engine oil in my 930 lp today and some coolant came out before the oil did maybe not far from being a quart. It overheated I think once last summer as I was working it pretty hard. This means either a blown head gasket or cracked head doesn't it? Or possibly a cracked block :>/ I ran it a while this morning and it ran well. What do you guys think? R Wyler
Jeff From WI.
06-14-2004 15:48:05
 Re: 930 lpg has water in oil in reply to R Wyler, 06-14-2004 12:48:18
Hi, It could be a blown O-Ring on the sleeve. Or a cracked Sleeve Or Like you said Cracked Head Or Blown Head Gasket. I Wouldn't Think Cracked Block, Unless You Forgot to Put Coolant In Her? Start Her Up, Take the Radiator Cap Off & see if You Have Bubbles In The Radiator. You Probable Do, Then Start A Process of elimination. If it's that Bad. But it Will Only Get Worse. Sorry Jeff.
R Wyler
06-14-2004 17:08:49
 Re: Re: 930 lpg has water in oil in reply to Jeff From WI., 06-14-2004 15:48:05
Thanks for the info Jeff I will check that out. I just as well figure on some serious engine work. I have always kept it full of coolant.
