2390
joe
06-13-2004 20:18:01
I just bought a 2390 and the clutch is really jumpy it seems like you cant ease into it like you should be able to
Shane
06-15-2004 21:04:13
 Re: 2390 in reply to joe, 06-13-2004 20:18:01
We have 3 1070's, 2 1270's, and a 2390 and only the one 1270 is jumpy but only in 4th gear, course it has well over 10,000 hours on it. Maybe one of your valves is stickin up a bit or an O-ring is a bit worn.
leland
06-15-2004 06:22:47
welcome to the case world most 70 and 90 series tractors i have driven strrt like you are sitting on unbroken horse .but dont worry they all had enough power to pull the hinges off the doors of hell , and were great on fuel drove a 1070 and could mow and bale hay for a week on a tank of fuel ,also make sure you keep hyd filters changed about every 200-250 hours trans will last a lot longer and we found out the hard way use cases hyd-trans oil only good luck p.s. when you back up wagons use 1st gear and rev or other wise you will buck and jump a lot
Jim P
06-13-2004 22:13:07
Welcome to the 90 series world. It's not a clutch, it's a dump valve. or at least it acts that way. Mine's been that way since new 1980. it now has 6600 hrs. and still work perfect( not a min.'s worth of trouble with the clutch, but it's still jumpie). If you wanted a smooth clutch you shoud have gotten a 930CK six speed with a oil bath clutch.
