Where to start on a 500 Diesel
Walter
06-13-2004 19:41:01
Just got a pretty good looking 500 in that doesn't have a battery all other parts are there. I was told it was running 6 months ago?? Engine is free and turns over good, no oil in water no water in oil. What sequence should I follow on trying to start it. I've restored 2 LA's. I know very little about 500's and diesels. Any suggestions appreciated. I pulled it a short distance but no smoke or attempt to start.
mike's600
06-14-2004 03:56:37
 Re: Where to start on a 500 Diesel in reply to Walter, 06-13-2004 19:41:01
Make sure the injector pump components are not stuck before you turn the engine. Sometimes the plunger will stick in the head,starting in this condition will break it. Very expensive to fix!!
Jerry
06-13-2004 21:10:58
I have just acquired 500 Diesel a little while ago. I had to rework primary fuel pump to get it to pump fuel so I could prime the system. To Start, I opened the top plug on final fuel filter and put tractor decompressor on, then cranked it with starter till fuel flowed without bubbles. Then closed the bleed screw and cranked engine to a high spin and had trottle set at 1/2 to 2/3 setting and closed decompressor lever and the old 500 after sitting 9 or more years coughed to life. Make sure shut off is pushed in on injector pump to start. And main fuel valve on tank is on. Jerry
Walter
06-14-2004 05:04:07
 Re: Re: Where to start on a 500 Diesel in reply to Jerry, 06-13-2004 21:10:58
1)Main fuel valve is on.
2)Not sure where primary fuel pump is, is this different from the injector pump?
3)Fuel coming out of top filter bleed screw. But I have not tried it while turning engine over.
Jerry
06-14-2004 07:50:54
 Re: Re: Re: Where to start on a 500 Diesel in reply to Walter , 06-14-2004 05:04:07
Walter, does it have compression? Primary pump is bolted on side of injector pump. Ifyou leave bleed screw loose on top filter and turn engine over and see plug come up or fuel flowing faster , pump is working. Mine had some extra piping on it to bypass primary pump so to assist in bleeding air out of system I think. I don't know if it was origional. but that bypass line needs to be turned off. Decompressor lever is on right edge of trans. housing towards the fuel tank. Up is on, down is off for decompression. You might have to loosen an injector line to let air escape or to see if fuel is being pumped. good luck.
Walter
06-14-2004 20:57:29
 Re: Re: Re: Re: Where to start on a 500 Diesel in reply to Jerry, 06-14-2004 07:50:54
1)we do have compression
2)we do have fuel flowing out of the primary fuel pump when i loosen the bleeded screw on top of it.
Its what is mounted below my injector pump the fuel tank line goes to this thing,,, I assume it is the primary pump. This is gravity flow.
3) when I take the bleed screw off of the top fuel filter i can see fuel in it,,, then when i crank engine with decompression on,, fuel does NOT flow out of the bleed screw but it does move up and down. Is this normal or not?
jerry
06-14-2004 21:38:22
 Re: Re: Re: Re: Re: Where to start on a 500 Diesel in reply to Walter, 06-14-2004 20:57:29
Walter, the fuel should come out of bleed hole on top of final filter when you crank the engine. You do not need decompressor on or off (I like to have decompressor on when bleeding system because engine spins faster and battery last longer) to have fuel come out of bleed hole on top filter If primary pump is functioning while cranking engine. Make sure bypass line is shut off. Primary pump should have about 5 - 10# preasure. I had a sheared pin on primary pump when I got my 500. Had to fish drive gear for pump out of bosch pump. To take off primary pump, just unbolt fuel lines and take 2 bolts (out of pump bodu and pull sraight out. Take all 6 bolts out of primary pump and can look at primary pump gears.
Walter
06-15-2004 20:39:43
 Re: Re: Re: Re: Re: Re: Where to start on a 500 Di in reply to jerry, 06-14-2004 21:38:22
well jerry we ain't getting no fuel so I'll just have to wait till i get a manual or I'm just wasting my time.. thanks for the input and I'll post something soon about the 500 .. I got it to hit on ether today but fuel is just not getting to the injectors. Cracked a line and spun it ...nuthin.
Jerry
06-15-2004 22:06:55
 Re: Re: Re: Re: Re: Re: Re: Where to start on a 50 in reply to Walter, 06-15-2004 20:39:43
Walter, You don't get fuel to injectors? Or injector pump? Are you getting fuel out of top fuel filter bleed screw when spinning engine? You could try applying air preassure to fuel tank by cutting valve stem from old innertube and hose clamping it to fuel tank then apply just enough to give the system a couple pounds of preassure. DO NOT put more preassure in than just a couple pounds at most! Manuals?!! What are they? More fun without instructions! Keep us posted to your progress. Must be a kinked fuel line. Had a D17 Diesel that had a rubber hose line to pump and that was up against the injector housing and eventually it blocked off fuel flow.
Walter
06-17-2004 17:42:38
 Re: Re: Re: Re: Re: Re: Re: Re: Where to start on in reply to Jerry, 06-15-2004 22:06:55
Just checked at the injectors, every line I open has fuel in it but when I turn engine over none comes out. What is the key shaped thing on top of the bottom filter under the injection pump? When I pressure the tank how far downline should I get fuel flow? All the way to the injectors or just up to the pump?
