Case 420 or 420B?
Bill
06-13-2004 18:24:00
I just purchased a case backhoe in rough shape. The ID tag says model 420-B-H. Is this considered a 420 or 420B. Also, the hydralic clutch is not working. Not knowing alot bout it, are there wear items inside?
Patrick
06-14-2004 20:19:36
 Re: Case 420 or 420B? in reply to Bill, 06-13-2004 18:24:00
Bill, a serial number would be the easiest way to tell what your tractor is exactly. However, if in referring to "the hydraulic clutch" you are describing a torque converter (Case-O-Matic) type of drive, then the tractor would have to be of the 'B' series, as no '400' first series tractors were ever sold with Case-O-Matic. That option did not appear until the 'B' Cases.
