8, 9, 1030 tranny, rear end
Ohio Case
06-13-2004 17:43:32
Are all the parts the same on the 8-speed models or are the 830's lighter? I am thinking about using a 30 series as a platform for a hot farm puller. Any suggestions?
Thanks for your time
Lamont
06-13-2004 21:45:46
 Re: 8, 9, 1030 tranny, rear end in reply to Ohio Case, 06-13-2004 17:43:32
You definitely need to go with the 930 or 1030. The 830 is tough but you're talking hot farm pulling. Good luck !!
Patrick
06-13-2004 20:33:28
It is my understanding that the 830 driveline is the same as 730, and nearly the same as 700B-800B and 400 series Cases. The 930 8-speed and 1030 used a modified (strengthened) version of the 830 driveline, so some parts will likely interchange, but other parts are beefed up on the larger models.
