Help ! How to fix 580CK brakes ? Main hydrauli
Rick Fedorchak
06-13-2004 07:50:02
All, now that I've got the backhoe running, does anyone have suggestions about how to attack fixing the brakes ? I live on a hill so having these operational is a must. I have the service manual showing the arrangement of parts, but I suspect that there are probably "tricks" to pulling this job off successfully. Thanks in advance for any help you can provide. Also, if anyone has suggestion on a good source for brake parts (linings, etc) please pass them on. Another thing. My bucket and hoe work, but I'd like to go through and drain, refill, bleed the hydraulic system. ( as well as replace any filters in the system) Where do I start ? What type hydraulic oil is used ?
thanks, Rick
