Thanks ! I got my 580CK diesel running !
Rick Fedorchak
06-13-2004 07:42:34
Thanks to forum members Patrick and rod for their suggestions in getting my "sitting for 5+ years" 580CK diesel backhoe running. After going through the fuel system (including new fuel and filters), changing oil filter and oil, and installing some new battery cables and battery, the beast started after about 20-30 seconds of cranking !! The suggestions Patrick and rod provided really helped. Thanks guys !
Patrick
06-13-2004 20:52:01
 Re: Thanks ! I got my 580CK diesel running ! in reply to Rick Fedorchak, 06-13-2004 07:42:34
Rick, glad to hear of your conquest. That makes the effort of writing posts here all worth the effort. If you ever run out of projects, I'll let you work on some of mine--HA! Now about the hydraulics, if you want to change the fluid you will have to drain both sides of the loader frame, as each forms part of the reservoir. The drains are inboard on each side of the frame, near the lift cylinder pivot. It should take approx. 11 gallons to refill the tanks. The plug to check the level is located on the right side loader frame upright member, about half-way up. Remove this plug and also the breather on the top of the frame. Fill the reservoir until fluid comes out of the check plug. The filter is located in the aluminum housing just to your right as you sit on the seat. Use a good six-point socket to loosen it by the top hex head. The new filter will come with a new o-ring to replace the seal. I posted the filter number in an earlier discussion with you, so just check back there for the part number. Use any good quality hydraulic fluid that says it meets specifications for Case TCH fluid. Just be sure to pick one brand and stay with it for all your future top-offs. Its best not to mix different brands of oils.
Rick Fedorchak
06-15-2004 03:26:47
 Re: Re: Thanks ! I got my 580CK diesel running ! in reply to Patrick, 06-13-2004 20:52:01
Patrick, Where would you suggest getting "TCH equivalent" fluid from ? Also, have you ever tackled fixing the brakes on your 580ck ? That's probably the single most important job I have ahead of me. BTW, While rooting around in my machine I found an old registration form from the construction company that owned this in the early 80's. It's actually listed as being a 1968.
I'd be interested in comparing notes on these without clogging up the forum. You can contact me at: [email protected]
Rick
