hyd. lift
philip
06-12-2004 18:22:25
case sc 1952 narrow frontend hand clutch/eagle hitch
the pto works fine, but the lift will not do nothing. already changed the hyd fluid. what is wrong?
Bruce Nelson
06-12-2004 19:36:35
 Re: hyd. lift in reply to philip, 06-12-2004 18:22:25
There is a roller chain that connects the PTO to the pump. Maybe it failed. There is also a coupler that connects the chain driven sprocket to the pump. I bet the pump is not turning for some reason. To remove the pump, drain the oil, remove the hydraulic filter on the RH side, then disconnect the linkage, hoses and the four attaching bolts. The whole story will be lookin' at you then. Good luck, Bruce
