dc hood
Richard
06-12-2004 15:44:02
What do the hood hold downs look like?mine has big nials in it and I'm sure its not right.thanks Richard
mike's600
06-12-2004 18:45:22
 Re: dc hood in reply to Richard, 06-12-2004 15:44:02
The hood has four studs fasten at four corners.The studs slip into brackets , screw on the the four nuts and you are in business.
Paul f
06-13-2004 05:11:55
 Re: Re: dc hood in reply to mike's600, 06-12-2004 18:45:22
Actually there are 6 studs that are riveted to the hood,2 at front 2 at back and 2 more about 2/3s way back (I only have 5 one was ripped off taking a piece of the hood with it :-( The front 2 have 2 rivets each the back 4 only 1 rivet. The back 4 mate to small plates with U shaped slots with small ears bent down at the end. You can have the 3/8 nuts and a washer threaded on the end of the stud, push it into the slot and it will stay there while you get the others on and then tighten them up. The front two connect to slots cast into the radiator housing
Larry Martin
06-12-2004 15:47:44
It is held down with 3/8" bolts.
