bubbles at top of radiator
Jerry Hahn
06-12-2004 03:41:41
It`s a Case 470 188D utility: Are these engines prone to leaking compession into coolant? There are less than 1000 hrs. on eng. (really, I bought it from orig. owner). I getwater (bubbles) blowing out of rad cap while raking hay, mostly, as that`s the main job for tractor right now. The temp guage does read high, but can put hand on top of rad. More, I have sheet metal off being painted, so have view of rad.
Tom (Ks)
06-13-2004 09:11:01
 Re: bubbles at top of radiator in reply to Jerry Hahn, 06-12-2004 03:41:41
My 530 pushed water out the radiator when I bought it. They removed the thermostat to fix the problem, but that did not help. The last guy that overhauled the engine put narrow flange sleeves in a wide flange block. The head gasket could not seal off the compression so it wound up in the radiator. Hope this helps.
