Case 210 Parts
Bob
06-11-2004 07:06:10
My uncle has a Case 210 that he is restoring. My questions are: Is there somewhere on the tractor that you can identify the year of mfg? He thinks "57" or "58".
Is there a good parts source for these? He needs a grill and steering wheel. I know absolutely nothing about them, am just trying to help him out since he does not have access to the net.
Am thanking you in advance for any help you can offer.
Mike Johnston
06-11-2004 08:20:20
 Re: Case 210 Parts in reply to Bob, 06-11-2004 07:06:10
There is a Serial Number link on the left side of this page. If you have the number you will be able to determine the year. 58 or 59 is most likely. I am not sure if any were made in 57. The utility model has a solid, non adjustable front axle. Does yours have a front loader?
There is a poster on this message board by the name of John Davis that makes an aftermarket grill. I don't have his number handy, but if you do a search of the archives here you will find it.
The 210-B is a great little tractor, and pretty rare. Not many of them made, compared to the others.
Mike Johnston.
Scott Flynn
06-12-2004 07:30:08
 Re: Re: Case 210 Parts in reply to Mike Johnston, 06-11-2004 08:20:20
Mike,
Did you try the rebuild kits on the power steering cylinder? Got mine installed and it works much better now. Can actually steer under a load! Bad news is that I determined that the cylinder rod is bent. Steering would work much better if I could locate another cylinder or at least the rod end. Any thoughts on a good source?
Dennis/Ohio
06-13-2004 03:32:26
 Re: Re: Re: Case 210 Parts in reply to Scott Flynn, 06-12-2004 07:30:08
Hi Mike,
Is yours the same as a 210B? Rod end part# G45373?
What rebuild kit are you talking about?
Thanks Dennis, [email protected]
Bob
06-11-2004 07:12:27
I might add that it is also called a "Utility"?
