case 530 backhoe problem
Grams
06-10-2004 14:38:49
I recently posted a message about a radiater problem on my case 530 deisle backhoe. After running for about 2 minutes it would shoot water out of the overflow. The replys that I got said that it probably overheated warped the head and blow the head gasket. I tore the machine down and the head gasket looked fine, I had the head tested and it wasnt warped, or cracked. Everything there seems to be ok. I am trying to figure out what else could cause it to shoot water out of the overflow after running only a couple of minutes. Any suggestions are greatly appreciated. Thank You.
mEl
06-10-2004 17:48:02
 Re: case 530 backhoe problem in reply to Grams, 06-10-2004 14:38:49
Check the sleeve protrusion at the deck,In the early 530's with the narrow flange sleeves, the sleeves would settle into the block, destroying the clamp force of the head gasket. The sleeve lip should be minimum .002, out of the block and all should be even, none lower than the rest. If there are any low, the block can be updated to the later wide flange sleeves if not equipped that way already by a competent machine shop, I have done many of these very sucessfully. As the previous post stated check for the crack 1/4 in down running around the sleeve, have also seen many of these. mEl
RoyG
06-10-2004 16:46:05
While you have the head off take some fine emery cloth and clean the sleeves good from the top to about one inch down and look for a crack around one of them. Also look for a vertical crack in one of them.
