need mole mashing advice
todd hamilton
06-10-2004 04:03:37
We have a mole tearing up the back yard. I take the SC and mash his tunnels with the front wheels and the smooth it out with the rear tires. This only seems to enrage Mr. Mole as the tunnels and mounds are bigger the next day. I would shoot it but it make the neighbors nervous when I sit on the back patio with the shotgun!:^)
thanks for all of the adv
06-10-2004 20:22:37
 Re: need mole mashing advice in reply to todd hamilton, 06-10-2004 04:03:37
Once when we were kids, my brother stuck a garden hose in the tunnel, turned on the water and shot the mole with the 12 gauge shotgun when it came up for air. Of course then we had to fix the yard and buy a new hose (Dad was not pleased). There wasn't enough mole left to make any mess to clean up. I was going to try the .410 on this mole but my wife won't let me (she never let's me do anything!)- Todd
Keith-OR
06-10-2004 22:39:02
 Re: Re: need mole mashing advice in reply to thanks for all of the adv, 06-10-2004 20:22:37
since you are driving your tractor to run over the mounds, get some flex hose, dig to find opening, put flex hose over your axhuast stick it in the hole cover it up around flex hose so they get all the carbon monoxide. Let it run for 30 minutes or so. END of rotents. My dad used this method when I was a kid. all else had failed.
chris
06-10-2004 18:32:51
what i used was a regular flip open trap, the half moon type you flip open. anyways dig a hole into the mound until you reach the tunnel, lay the trap carefully in the path. cover slightley with dirt. then place a piece of plexiglass over top and cover with dirt. all except a place the size of a quarter. point being sunlight will show down the tunnel, he will come to cover this pinhole up and whap
Mike Schotte
06-10-2004 07:51:24
Hey Todd,
I ran across this on the web a few months ago- and it would make Carl's (the greenskeeper from Caddyshack) day!
It's a propane powered device for burrowing rodent control:
"Manufactured by Meyer Industries, the Rodenator Pro TM uses a controlled mixture of propane and oxygen that is injected into the rodent's burrow. A built-in, self contained ignition system then ignites the mixture, creating an underground shockwave or concussion that instantly eliminates the rodent and collapses the tunnel system."
You have just GOT to see the videos of this thing in action... (see link below)
-Schotte
Keith-OR
06-10-2004 22:03:26
 Re: Re: need mole mashing advice in reply to Mike Schotte, 06-10-2004 07:51:24
seen one of those things in action, Couple of friends and I go to S Eastern Oregon to shot Belding ground squirrels couple time a year. You think gofers and moles are bad, the squirrels are worse than Prairie dogs they eat up more than 1/3 of the farmers hay crop, let alone make large holes that horses and cows can step in and break legs. Last year friend and I set in the same spot and shot for 10 1/2 hrs along with other people there. When we were done you could not tell that we had mad a dent in them. One of the ranchers where we go was using this contraption. Standing 20 feet away when he set it off could feel the ground raising under my feet. It actually blows some of the rotents out of thier holes twenty feet in the air. Very impressive. It looks like a weed burner with sparkplug at the bottom and a coil to provide the spark. Was told only put in gas and Oxygen for 15 secs...
ZK(WA)
06-10-2004 09:38:10
COOL !!! I'll have to get me one of those setups.Although ammonia has worked for me a number of times, this looks like at lot more fun. Aerates the lawn too. What a deal, the proverbial two birds....
Bob - MI
06-10-2004 06:34:59
I have LOTS of moles due to lots of woods surrounding my lawn. I got a trap years ago that is really good. Made by Nash Products it's called a Choker Loop mole trap. Comes in a green and red box. Most good hardware stores and lawn care centers will have it.
You leave most of the tunnel open except for a spot where you will put the trap. Step a flat section down and cut slits in the ground with a spade. Trap loops go in the slots and when the mole comes back through the spring trips and the loops pull him up against the bottom of the trap and choke him. All the action is under the ground and there's no blood and gore. Just a dead little furry critter that's dug his last tunnel.
I have three of these now as they have a tendancy to invade the lawn on multiple fronts. I have sold a few in my neighborhood by loaning my traps to the neighbors. They really work and they are under $20.00 Got my first about 20 years ago and it's still working fine.
Roger
06-10-2004 06:29:24
Todd, when I was in Indiana years ago, a guy would come over to the shop & get anhydrous ammonia in a 20 lb propane bottle that he changed valve in, he used it to get rid of ground hogs if they dug under the buildings, a whiff of ammonia in the mole tunnel & no more mole.
Robert Pence
06-10-2004 13:22:14
 Re: Re: need mole mashing advice in reply to Roger, 06-10-2004 06:29:24
Nowadays, if somebody had anhydrous in a propane bottle, most folks around here wouldn't assume he was using it to get rid of groundhogs! He'd probably get a visit from the local law enforcement types with hazmat gear, looking for his meth lab.
Roger
06-10-2004 13:31:50
 Re: Re: Re: need mole mashing advice in reply to Robert Pence, 06-10-2004 13:22:14
That's true Bob, it was back in '84-85 when he would get ammonia from me, no one knew what meth was back then.
Paul f
06-10-2004 05:54:46
Rent the movie CaddyShack...Bill Murray had several good ideas for gophers...should work for moles too :-)
Ryan
06-10-2004 05:40:22
One thing that worked well at a construction job that I did was awareness and a potato fork. Watch the end of the tunnels and you will see them move a bit whenever the mole is digging some more. Quickly, step down about 8 inches from the end of the tunnel. This blocks the mole in. Then take a potato fork and stab the living hell out of the ground between your boot and the end of the tunnel. You would be surprised how much of a mess a single mole can make, and how nice the yard is afterward.
GeoMo
06-10-2004 05:23:09
They say if you kill your grubs that the moles will leave. I would hate to kill the earthworms so I have never tried. I don't have one very often.
Bobcat
06-11-2004 06:42:47
 Re: Re: need mole mashing advice in reply to GeoMo, 06-10-2004 05:23:09
I've tried about everything already posted here and found that getting rid of your Grubs is the only way to get the moles out of your yard. And yes you will have to dig for worms somewhere else too!
mike
06-10-2004 05:13:08
I don't know about moles, but I have gofers in the back yard, its just a blast to mow lawn over their mounds. My wife uses chewing gum, digs out the mound to find the hole, places a new piece of gum(no human contact with gum as to alert to scent) and it seems to take care of them, They stop digging shortly after.
JohnM
06-10-2004 05:05:59
We used to use smoke bombs from Agway. Worked pretty good too.
