Different front hubs for DC??
Larry W.
06-09-2004 21:04:07
Alright guys, heres a question I hope someone has a good answer for. Is there any other six bolt front hubs that will go in place of the cast monsters on a DC without remachining the spindles, you know, just one of those directe replacement! LOL Someone told me at one time they thought hubs off a 700 Case might work, but were not sure.
Travis
06-12-2004 07:55:50
 Re: Different front hubs for DC?? in reply to Larry W., 06-09-2004 21:04:07
Front hubs off a 1030 case work.
Larry W.
06-12-2004 10:13:47
 Re: Re: Different front hubs for DC?? in reply to Travis, 06-12-2004 07:55:50
Travis, other than the hubs, what bearings do you use?? Have you done this before? Really appreciate any help, thanks!
Travis
06-12-2004 10:33:02
 Re: Re: Re: Different front hubs for DC?? in reply to Larry W., 06-12-2004 10:13:47
use everything for the 1030, the spindles are the same. I have a set on mine right now. I just took a set off of a 1030 and put them on a DC, easy fit. took an hour.
Larry W.
06-12-2004 11:46:52
 Re: Re: Re: Re: Different front hubs for DC?? in reply to Travis, 06-12-2004 10:33:02
Thanks Travis, I'll check into it, if this works, it will save me a lot of time!!
Travis
06-12-2004 15:38:41
 Re: Re: Re: Re: Re: Different front hubs for DC?? in reply to Larry W., 06-12-2004 11:46:52
should work, I did it to mine.
bill
06-10-2004 16:59:14
wide front hubs are lighter and take pressed steel wheels I have found that sc and some dc wide adj hubs have the same nimber but use different bearings between the differnt tractors some dcs i have use a heavy caST wheel with demountable rim Be careful not to get the frontend too light as my wide adj front with pressed steel wheels will raise the front very easily
