970 surging at low idle
KYCASE
06-09-2004 16:36:42
I have a 970 case that the engine surges when it is at low idle. Is this a hard problem to fix? And is it causing any damage to the engine? Thanks KYCASE
Jim Handke
06-09-2004 19:47:36
 Re: 970 surging at low idle in reply to KYCASE, 06-09-2004 16:36:42
At the back end of the injector pump, there is a hex shaped cap. Remove the cap and you'll find an adjusting screw. Loosen the jamnut, and I believe you turn the screw in to smooth out the idle.
