Wanted - Gasket making tips
BasketCASE
06-09-2004 13:42:10
I am about to cut my own cork-rubber gaskets for the hand hole covers on my DC, and I was wondering what some of you have discovered is the best way to cut them out. Do you just use an exacto-knife and go slowly and carefully along the lines? And how do you cut bolt holes? I have 5/16" holes to cut, and someone suggested I use a roll pin sharpened on one end. Any other tips and suggestions? As always, thanks in advance.
Dave_D
06-14-2004 12:34:41
 Re: Wanted - Gasket making tips in reply to BasketCASE, 06-09-2004 13:42:10
I always use a bead of silcon and then lay some string in it. With it string ends over lapping at the top. The string help to keep you from crushing out all the silcon.
Work for me.
-Dave
Chico TX
mEl
06-10-2004 18:01:23
I agree with Tom, cept red silicone almost perfectly matches flambeau red, use it as a replacement for every gasket on our puller including the head gasket, much better than paper/cork. mEl
wolfe in tx
06-09-2004 20:52:46
Try spent ammo hulls all cal.all sizes
DCTOM
06-09-2004 17:47:48
UNLESS YOU WANT IT TO LOOK 100% ORIGINAL USE CLEAR CILICONE, MUCH BETTER AND EASIER DCTOM
RZ(WA)
06-09-2004 15:12:08
Skizzers, X-Acto knife and a hole punch made from a sharpened length of copper or brass tubing of the correct outside diameter. Oh yes, and carbon paper.
RoyG
06-09-2004 15:00:45
Don't go to the bother of making gaskets. Just use RTV Black silicone. It will hold better and longer than gaskets.
Brian in Ohio
06-09-2004 14:49:38
Depending on what kind of material you are using, you can use an exacto knife or scissors to cut your pattern. Personally, I was taught to use a ball peen hammer, and beat out the edges, and use a punch for the bolt holes. You can't always hammer out cork gaskets, as they like to crumble, but it's good for other materials.
C Nesler
06-09-2004 14:35:39
For what it's worth I have better luck cutting cork with scissors and a hollow punch for the bolt holes.
C Nesler
DougG
06-09-2004 20:44:48
 Re: Re: Wanted - Gasket making tips in reply to C Nesler, 06-09-2004 14:35:39
If you want to use the cork, (the advice on silicone is correct. It does work well,IF the surfaces are not oily.) The first thing is to get cork that isn't dried out. This maybe is the most important thing to know about using cork/ or composition gasket material. A lot of what you may get has been setting for a long time and will crumble or break if you bend it much. This stuff is useless. So you get some with a little pliability. lay it on the surface to be sealed, and you may use your thumb and run around the edges, this will make a line you may then cut.
you may also take a 4oz. ball peen hammer and push in on the bolt holes while rotating it, this willl cut them out if you do it correctly AND the holes are fairly sharp around the edge. At the least they will be darn well marked. Maybe this helps.
