VAC hyd pump rebuiild
John Mc
06-09-2004 05:59:40
I need to rebuild a hydraulic pump for my VAC. Any tips on doing this?
Where can I get parts?
This is the pump that mounts on the right side just behind the starter.
mj
06-09-2004 11:35:36
 Re: VAC hyd pump rebuiild in reply to John Mc, 06-09-2004 05:59:40
third party image
This is the first page in the section (image 27) so click on the link to see the rest. Click each image to enlarge and print.
John Mc
06-09-2004 11:59:07
 Re: Re: VAC hyd pump rebuiild in reply to mj, 06-09-2004 11:35:36
Great, thanks a lot!
C. Amick
06-09-2004 09:46:20
Is this the belt pulley driven pump? I've never seen one of these wear out. Was it damaged by running low on oil? I know that you can still get the hydraulic piston leather cups from Case/IH, but I don't know about hydraulic pump parts? Do you know what parts you need? Where are you located?
John Mc
06-09-2004 10:51:50
 Re: Re: VAC hyd pump rebuiild in reply to C. Amick, 06-09-2004 09:46:20
The pump has a gear that goes inside the torque tube, I assume this is what drives the pump and belt pulley. We removed it from an old torque tube off another tractor frame that had been sitting in the woods for many years and water ran out of it when we removed it. Whether it was working when parked I do not know. I am sure it needs some work, but I have never been into one like this. Located in SW Louisiana.
C. Amick
06-09-2004 11:43:26
 Re: Re: Re: VAC hyd pump rebuiild in reply to John Mc, 06-09-2004 10:51:50
The pumping is done by 2 spring loaded bucket type pistons that are pushed in by a rotating cam. Used parts should be fairly easy to find. Minneapolis Molines made around the same years used the same pump mounted on the side of their engines.
