VAC valve clearance
John Mc
06-09-2004 05:57:26
The specs call for "0.014C" clearance on the valves for my VAC. Does the "C" mean while the engine is cold? What is the proper procedure for setting the valve clearance?
I would not fool with them, but some of them have over .040 slack.
Bill-KCKs
06-09-2004 20:42:41
 Re: VAC valve clearance in reply to John Mc, 06-09-2004 05:57:26
Another aid to finding the compression stroke is to place a cork or rubber stopper in the #1 spark plug hole and it will blow out on the compression stroke. I never did find the cork I used on my Cat 22 crawler. Can't claim originality on this trick, I think I found it elsewhere on ytmag. Or maybe ACMOC....
C. Amick
06-09-2004 09:40:47
Remove spark plugs so that engine is easily turned. Rotate the engine until No. 1 piston is at top dead center on the compression stroke. You can tell if you are on the compression stroke by putting your thumb over the spark plug hole as the No. 1 piston comes up. Both of the No. 1 rocker arms should be loose when the piston is all the way up and the valves are closed. Spin your push rods by hand to see if they are bent. Each valve adjustment should have a lock nut. Hold the adjuster with a screw driver and loosen the lock nut. Adjust the valves at each cylinder in the order of firing (should be stamped on engine block). Pull the next piston cylinder to fire up to top dead center and adjust it. You can turn the engine with a crank or by the belt pulley nut with a ratchet and socket. The starter will turn it too fast and not stop where you want to stop.
Joe (Wa)
06-09-2004 10:34:02
 Re: Re: VAC valve clearance in reply to C. Amick, 06-09-2004 09:40:47
Firing order is 1342. TDC = top dead center on compression stroke.
Two easy methods of following firing sequence.
Once you have placed #1 on TDC and set both valves @ 014".
With the starting crank: Turn engine in direction of rotation (cw) 1/2 revolution (180 degs) and #3 will be TDC, set valves. Turn engine another 1/2 rev, set #4 and again to set #2.
If you have a distributor and are turning the engine with a wrench on the belt pulley nut or the crankjaw nut:
When #1 is TDC, take off the dist cap off, the points will be open with rotor contact under #1 wire tower. Set valves on #1. Turn engine in direction of rotation, rotor will turn cw. When rotor has turned 90 degs, points will open and #3 is TDC set valves. Continue turning engine until points open #4 set valves and again for #2.
Joe
Art
06-09-2004 06:34:22
yes Cold .04 sounds like you need to "fool" with them...
