VAC valve seals
John Mc
06-09-2004 05:52:57
I think I have a little oil leaking around the valve seals on my '45 VAC. I pulled the valve cover and there are no trace of seals around the valve stems. Did they originally have seals? Can I add seals and if so does anyone know a part number?
C. Amick
06-09-2004 09:58:03
 Re: VAC valve seals in reply to John Mc, 06-09-2004 05:52:57
Did you check to see that your oil return ports are not clogged? Oil leakage into the cylinders could be caused by too much oil in the head when running.
John Mc
06-09-2004 11:01:04
 Re: Re: VAC valve seals in reply to C. Amick, 06-09-2004 09:58:03
The head looks very clean around the rockers, but I will check the oil ports.
Thanks.
Art
06-09-2004 06:37:58
seals are only on the intake side only... they are hard to find...I think I got mine from C&L tractor parts, along w/ all my other valve parts Good luck
Jerry W
06-09-2004 06:13:45
I doubt if a VAC ever came with valve seals. Most valve seals came of age in the 60's.
I would go to a local automotive/light industrial machinist and see what he recommends.
Intake seals are more important than exhaust seals because of the vacuum on the intake side.
Jerry
