case 400
ts bruneau
06-08-2004 18:29:47
bought an old 1954 case 400..high profile..eagle claw hitch..... .the PTO slips...is there a way to tighten the PTO clutch??? thanks.tom
Tim
06-09-2004 11:51:26
 Re: case 400 in reply to ts bruneau, 06-08-2004 18:29:47
Tom,
Might want to check E-Bay for a manual. I got a used IT manual for my 700 (includes 400 also) for $10. If you're stuck, give me a shout - I can try to copy and fax or scan and e-mail that section to you. (If it's in the manual!)
Tim
leland
06-13-2004 21:07:52
 Re: Re: case 400 in reply to Tim, 06-09-2004 11:51:26
if you want a factory manual for a 400 find a guy called the paper boy he has thousands of manuals the only place i know for sure he will be is at jacksonville il at the end of sept at the steam show good luck if you want another 400 let me know my father inlaw just passed and his is for sale and also an L is there also
tsbruneau
06-10-2004 06:37:42
thanks tim...i cant find any inspection plate on right rear of tractor, only one that is below the battery, in the middle of tractor
..ill see if i can find a manual..tom
Tim
06-10-2004 17:31:48
 Re: Re: Re: case 400 in reply to tsbruneau, 06-10-2004 06:37:42
Tom,
Got a chance to look at the manual. It shows a pipe plug on the right side, just in front of the PTO shield. Looks like you need a special "adjusting tool" with a forked end. I think you better get a manual - I've read it 3 times and think I understand the directions. Let me know if you want me to type the directions out word for word. Think you still need the tool though.
Tim
tom
06-16-2004 06:35:45
 Re: Re: Re: Re: case 400 in reply to Tim, 06-10-2004 17:31:48
tim.. thanks a lot for the info..i think there is a rod with a forked end in the tractor toolbox...now to figure out what to do with it!! HA!..... .. tom
caseman-d
06-08-2004 20:02:57
it should have a clutch adjustment on the right rear side, you might want to find a manual on it. Should be a cover plate to remove.
caseman-d
