Changing a VAC engine
Ryan
06-08-2004 06:52:34
I am trying to get my granpa's VAC-14 back on the road. He parked it without covering the exhaust and the engine is stuck harder than any other I have ever seen. (took the oil drain plug out and 3 gallons of water came out before any oil. SO I am looking at switching engines. THe sn of the tractor begins with 6000 (1953 model right?) What engine does it have in it now and what will fit? I have a guy that has a swather engine, will that fit in the tractor?
Augie
06-08-2004 09:14:59
 Re: Changing a VAC engine in reply to Ryan, 06-08-2004 06:52:34
VAC uses the 124cid gas motor. 148, 188, 201 gas will go in with some modifications. I haven't heard of anything that's a direct bolt-up replacement for the 124.
JohnM
06-09-2004 08:03:24
 Re: Re: Changing a VAC engine in reply to Augie, 06-08-2004 09:14:59
VAC should be a sleeved motor. Stuck or not DonL should have a kit for it. If it is that bad just change both. Just my thoughts.
