730 brake adjustment
camper
06-07-2004 05:25:13
how do you adjust brakes on a case 730. 1964. I have no brakes. camper
Lamont
06-07-2004 20:01:38
 Re: 730 brake adjustment in reply to camper, 06-07-2004 05:25:13
If that adjustment rod won't tighten them up, you'll need to put new discs in there. While you're in there, replace the spreader balls with ones that are 1/8 inch larger. This works wonders. We've done this on every 30 series tractor that we've owned and have not had to work on brakes for over 20 years.
Roger
06-08-2004 06:49:32
 Re: Re: 730 brake adjustment in reply to Lamont, 06-07-2004 20:01:38
Lamont, where are you getting the bigger balls? are they just balls from bearings or something else?
Lamont
06-08-2004 15:23:10
 Re: Re: Re: 730 brake adjustment in reply to Roger, 06-08-2004 06:49:32
Just go to any bearing supply store. Mic your old ones. They should be 0.625 if I'm not mistaken. The new ones I used were 0.750 and work like a charm.
GeoMo
06-08-2004 05:17:31
I wish I had known about the larger balls. I replaced the cones ( only the really bad ones) at $12.00 X 6 per side.
I had a grease seal leaking, be sure to check. I washed every up and it worked fine.
Lamont
06-08-2004 15:25:35
 Re: Re: Re: 730 brake adjustment in reply to GeoMo, 06-08-2004 05:17:31
If your cones were really rough, they needed reworked anyway. Next time remember to go to your nearest bearing supply and get 0.750" bearing balls. They do wonders.
case poor in pa
06-07-2004 18:55:41
thres a rod come out of the brake drum to the pedal. turn the nut to about 3/4 inch free travel from the step to the brake. if that dont work.you proably will have to get inside the drum and spend some greenbacks hereit 50.00 a side for discs if you need them .. littls parts like the springs and ball bearings will make you gasp at the case dealer. not cus they cheap either. not a hard job tho hour and half do both sides.
