DC clutch adjustment
Scott KY
06-06-2004 19:26:54
Can a DC clutch be adjusted without the special adjusting tool that came with the tractor when it was new. How do you do it?
Paul f
06-07-2004 04:40:14
 Re: DC clutch adjustment in reply to Scott KY, 06-06-2004 19:26:54
Make your own tool with a larger flat tip screw driver...grind/file a "V" notch in the center of the blade then bend the shaft as necessary to get to the adjusting pin...You are basically pulling out a spring loaded locking pin that has a mushroomed top while you turn the collar (your "v" tool catches the thinner shaft just below the top)...it will also work to adjust your Live PTO Clutch pack
