Right twist steering gear for a VC
John
06-06-2004 18:37:17
Has anyone ever replaced one of these gears and know where to get one? I am talking about right twist because he got a new gear and says it is left twist, does anyone know what he is talking about? Asking this for a friend and will relay any info you u have. Thanks
Jerry W
06-06-2004 19:45:37
 Re: Right twist steering gear for a VC in reply to John, 06-06-2004 18:37:17
The difference is whether the tractor has a narrow front or a rigid wide front.
What it translates into is that one needs to push the arm forward to turn right and the other needs to pull the arm back to turn right.
On a VAC all front ends (wide or narrow) that have the steering arm pivoting out of the front casting need a gear that will push the rod forward to turn right.
The VAI and VAO fixed width wide frontend that uses the left spindle for its' pivot needs the rod to push forward to turn left.
Thanks Jerry
