Model L axle seals, axle flange adjustment
Nicholas A. Cov
06-06-2004 13:19:53
I was wondering if replacement axle seals might be available, or if the felt-like material can be replaced? Once they are replaced, the wheel is remounted and tightened, the flange nut is just turned out until the desired clearance is obtained, correct? Is there a specific clearance needed on these for the axle bearing? Also, where would be a good source to obtain a repair manual for this tractor, that would contain information of this nature, original or reproduced? Thanks in advance, Nicholas.
Butch/ OH
06-06-2004 14:26:15
 Re: Model L axle seals, axle flange adjustment in reply to Nicholas A. Covey, 06-06-2004 13:19:53
I have an owners manual that contains those kind of maintenance instructions.
