DC carb
Scott KY
06-05-2004 19:06:55
I've been working on a 39 DC that has been setting awhile. Got it running but it runs rough. When I adjust the idle screw in the top of the carb it makes no difference. I can screw it all the way in or out and it does not change how it runs. I have taken it apart and everthing looks ok. It was rebuilt not long ago. It is a zenith. Any ideas?
C. Amick
06-06-2004 17:37:39
 Re: DC carb in reply to Scott KY, 06-05-2004 19:06:55
Is it putting out any black smoke? With it running, I would pull off a plug wire and put it back on, one cylinder at a time, to see if the problem might be with something else. If you pull one off and it doesn't change how the engine runs, then you've found the problem cylinder.
C. Amick
06-07-2004 05:53:26
 Re: Re: DC carb in reply to C. Amick, 06-06-2004 17:37:39
I think you would have better luck running Autolite spark plugs. I think I run Autolite 295's in my SC. I don't know what the proper Autolite plug is for a DC?
Scott KY
06-06-2004 19:23:29
I think I found the problem. #1 spark plug had alot of black soot on it. I cleaned all 4 and it runs pretty good. By the way the plugs are champion D15's. Should I use a hotter plug?
