David Brown 1210 timing gears
Jeff
06-04-2004 18:53:28
Can anyone tell me how the timing gears in a DB 1210 get their lubrication? They seem noisey and looked dry when I looked in the filler hole. I poured a little oil in and they quieted down. Turning the power steering from side to side also quiets them. Any ideas?
Elmer
06-04-2004 19:51:45
 Re: David Brown 1210 timing gears in reply to Jeff, 06-04-2004 18:53:28
The shaft for the idler gear is pressure fed and splash from it lubes the rest. If you have the course cut gears you better change them now with the later fine cut set. They are noisy due to wear. I have seen them completely trashed and cause all kinds of problems. Like break the end of the camshaft off. I can supply you with a new set if you need them.
