450B Case Loader (low tranny pressure)
John
06-03-2004 16:27:50
450B Case with low tranny pressure, anyone got any suggestions?
DaleIN
06-03-2004 17:12:57
 Re: 450B Case Loader (low tranny pressure) in reply to John, 06-03-2004 16:27:50
Hi John,
Might be the engine mounted charge pump (let me know if you need one). Or, if its just slow picking up pressure, it could be sucking air in one of the 1.25" ID hoses between the pump and tranny. (Sometimes they'll suck air in, but not necessarily leak oil out).
Good luck, Dale
John
06-05-2004 19:56:09
 Re: Re: 450B Case Loader (low tranny pressure) in reply to DaleIN, 06-03-2004 17:12:57
Dale,
Thanks, you were right on the money, replaced the hoses, cleaned the screen and changed the oil. Pressure in the green.
Now, it runs good but get a little sluggish after awhile. Seems like the brakes are on. What do you think?
DaleIN
06-06-2004 13:37:08
 Re: Re: Re: 450B Case Loader (low tranny pressure) in reply to John, 06-05-2004 19:56:09
Do both or either brake housings get warm? If not, how tight are your tracks? If they are too tight, it will feel like the brakes are on. You should have at least an inch or so of sag between the front idler and top roller.
