back blade for eagle hitch VA
swamp farmer
06-03-2004 13:44:09
Will any back blade fit the eagle hitch, or do I need to look from a specific manufacturer? My loader only has a trip bucket and no downward pressure, so I need to look for another solution to moving snow around (and Christmas is coming). Any help for a rookie greatly appreciated.
mj
06-05-2004 14:37:02
 Re: back blade for eagle hitch VA in reply to swamp farmer, 06-03-2004 13:44:09
Loosen the draft-arn brackets that mount to the axle and mount your Cat. 1 blade...re-tighten the bracket bolts.
Eric Rylander
06-04-2004 16:11:20
I have fond memories of moving tons of snow over the years with trip bucket loaders without down pressure. You don't need it on gravel driveways, you'll dig in too much. Never used a blade.
swamp farmer
06-07-2004 20:33:39
 Re: Re: back blade for eagle hitch VA in reply to Eric Rylander, 06-04-2004 16:11:20
The problem is the loader only drops so much, and leaves behind a 2" layer. That builds up and gets icy, causes humps and holes. Our stock trailer eventually can't be hooked up to the truck without using a farm jack to get the front end up high enough. We get serious snow, and the bucket on the loader doesn't drop down low enough to skim it off the driveways. It's at its worst when cresting a hill - then I leave behind 4". That's why I've decided on the rear blade. That way I can push it to a bank, and then lift and carry most of the bank away. There might be a way to allow the loader to drop down far enough regardless of slope, but this rookie doesn't have a clue how to do it. I thought the bucket would do everything I wanted, but not with snow.
C. Amick
06-04-2004 05:38:03
Sometimes you can swap one or both of the Cat 1 pins on the blade to the inside to get the spacing width right.
swamp farmer
06-04-2004 05:45:43
 Re: Re: back blade for eagle hitch VA in reply to C. Amick, 06-04-2004 05:38:03
thanks for the tips and info - there's a nearby reversible blade for sale at $350. I'll find out if it's a cat 1.
Much Appreciated!
GeoMo
06-04-2004 05:23:37
I use my Dad's Dearborn blade on my VAC. I have to remove the drawbar to allow blade to be lowered to blade dirt.
Jerry
06-03-2004 18:05:16
Swamp Farmer. I have the rear blade that my dad had on the 1950 VAC , it is a 6 foot john Deere blade cat 1 . So any cat 1 blade will work just check the distance between the arms and then measure the blade you are looking at ,so Santa gets the correct blade.
Jerry
