Identifying VAC carb
Mopower
06-03-2004 06:42:59
Was a VAC carb a TSX 635? My friend needs one. He says it was on a 430 case and Oliver 77 too. Not sure if that is right. I use M-M.
Joe (Wa)
06-03-2004 10:22:50
 Re: Identifying VAC carb in reply to Mopower, 06-03-2004 06:42:59
The common carb found on Vac's 124 cid engine is TSX-114. TSX 635 was for the 148 cid engine in the 300 series and others.
The mounting of the carbs differ in that the throat of the 114 is aft and the 635 is fwd and thus the throttle linkages and idle mixture screws are on the opposite sides.
Internally the carbs are very similar and have many of the same parts. I suspect the main jet is different. I don't know if they are interchangeable with some mixture adjustment but suspect it can be done.
Joe
