VAC Belt Pulley Oil Seal
Paul f
06-03-2004 05:18:51
The belt pulley shaft on my VAC (#5451349 no hydro pump on the pulley) leaks. Parts book says # of the seal is VT2316...my friendly Case dealer parts guy can usually find what I need but not this time. I have looked at outside of seal but I don't see any markings. I know that it would be possible to remove the seal take some measurements and start visiting bearing and seal places but a drippy seal is better than none at all
Does any member of this august group know of a valid part# seal # for this seal????
Thank you
Joe (Wa)
06-03-2004 10:30:23
 Re: VAC Belt Pulley Oil Seal in reply to Paul f, 06-03-2004 05:18:51
The cross-ref nr for VT2316 is A29984 in my manual (1967).
Joe
Paul f
06-05-2004 06:28:03
 Re: Re: VAC Belt Pulley Oil Seal in reply to Joe (Wa), 06-03-2004 10:30:23
Joe: Thank yo very much...I'll call my parts guy Monday
Mike
06-03-2004 05:34:13
Paul,
Mine also leaked and I removed the old seal and took it to NAPA. replaced it with a generic, actually I ended up replacing it with 2. the shaft was wore slightly and didn't quite stop the leak. There is room for another right next to the first and that fixed it. Did the same thing with an axle seal.
Paul f
06-03-2004 05:48:51
 Re: Re: VAC Belt Pulley Oil Seal in reply to Mike, 06-03-2004 05:34:13
Mike: Do you happen to know the number?? Unlike my Case guy the Napa folks aren't real swift and it takes them forever to get parts
Thank you Paul f
Mike
06-03-2004 05:53:26
 Re: Re: Re: VAC Belt Pulley Oil Seal in reply to Paul f, 06-03-2004 05:48:51
Paul, I'm sorry I don't. My grandfather got the seal one afternoon and had it all put in before I got there to work on her. I'll check around to see if he still has the box.
Paul f
06-03-2004 06:33:24
 Re: Re: Re: Re: VAC Belt Pulley Oil Seal in reply to Mike, 06-03-2004 05:53:26
Thanks I would much appreciate that
