Case 530 Power steering cylinder
Ron
06-02-2004 12:55:55
I have been looking everywhere but have been unable to come up with a replacement power steering cylinder for my 530. This is the single cylinder model with the control unit on the cylinder. Any help is greatly appreciated!
Ron
06-03-2004 19:11:38
 Re: Case 530 Power steering cylinder in reply to Ron, 06-02-2004 12:55:55
It is not a power problem stemming from the pump. It is just years of use and someone not taking the time to repair it correctly. It has come to the point where it is going give out and I will not be able to patch it anymore.
Dennis/Ohio
06-04-2004 00:02:44
 Re: Re: Case 530 Power steering cylinder in reply to Ron, 06-03-2004 19:11:38
Hi Ron,
I'm sure you can find this cylinder on older Case Utility tractors or so similiar you can use it. Case had a standard and a heavy-duty axle with slightly larger piston diameter. I don't know years or models but I've seen the same I-beam axle and assist cylinder on utility tractor other than a 530. Dennis..... .
Dennis/Ohio
06-02-2004 19:57:00
Hi,
I think you have a Utility tractor. The rod seal kit is available but the welded cylinder is not. I'm thinking a good hydraulic shop can cut the cylinder open on a lathe, rebuild the piston and weld it back together.
I don't know what you've checked but check the pump pressure before you blame the assist cylinder?
Best wishes, Dennis..... ..
