CASE Series 630 Won't Go Into Reverse
Joe
06-02-2004 10:12:49
I have a CASE Series 630 tractor. The other day after about 3 hours of being in the field the shifter decided it didn't want to go into reverse anymore. All other gears are fine. I tried rocking it a bit to see if I could 'reset' the linkage assuming it may just be out of wack given it's age. I can get it about 1/4 the way in the gear slot and when it is running I can hear it try to grind to get into gear (don't worry, not a habit I practice). Any ideas?
John Saeli
06-02-2004 18:24:20
 Re: CASE Series 630 Won't Go Into Reverse in reply to Joe, 06-02-2004 10:12:49
Hey Joe: Sounds like a bent fork. Simple to remove the cover & check.
Joe
06-04-2004 10:07:32
 Re: Re: CASE Series 630 Won't Go Into Reverse in reply to John Saeli, 06-02-2004 18:24:20
Thanks for the feedback John. If that were the case, and it were you, would you try to elegantly bend it back or would you be looking at at kit or something?
