Transport chains on 530CK
Mike Fallavolli
06-01-2004 22:19:12
third party image
Hi,
Does anyone know how the transport chains for the backhoe were originally setup on a 1964 530CK? Mine are long gone and I'm going to have a welder doing some work for me on Friday. I'd like to replace the chains so I don't have to keep reaching back to pull in the boom. (Leaking cylinders.)
I know that one end was welded just under the foot controls but what was on the end of the chain and where did they connect. I'm thinking of just putting hooks on the end of the chains and hooking them onto the boom. There are these long pockets on the boom that I don't understand the purpose of. I'll try a link to a picture of what I'm thinking of doing.
Link
Any thoughts?
-- Mike
DaleIN
06-03-2004 17:04:43
 Re: Transport chains on 530CK in reply to Mike Fallavollita, 06-01-2004 22:19:12
Hi Mike,
Or, you could do it like on the 580CK: weld one end of a chain to each stabilizer leg, and fabricate a hook on each to engage the loop on the boom...that way, the boom AND stabs stay up. Just a thought...Dale
Dan Doell
06-02-2004 23:52:32
Thanks for the info. I have a 1964 530 CK that I just purchased, the first time I ran it, it dug itself into the ground because I didn't notice that the bucket had gone down by itself. One of the hydraulic hoses sprang a leak. I just kept pouring on the coal, and down it went. I have several questions I would like to ask about my tractor. What is the capacity of the hydraulic pump? It doesn't have a PTO and I was wondering if it would support a Hydraulic motor mower?
Dennis/Ohio
06-03-2004 23:41:48
 Re: Re: Transport chains on 530CK in reply to Dan Doell, 06-02-2004 23:52:32
Hi Dan,
If you have the loader and hoe I'm sure you're 20 G.P.M @ 1900 RPM or 22 G.P.M. @ 2100 RPM. Reservoir capacity of 11 gallons. The info I couldn't find is for loader alone. I'm thinking the pump is around 18 gpm @ 1900 rpm. And possibly using one side for a reservoir which would be 5 1/2 gallon. Maybe this is enough to help? Dennis.....
gwinnibarge
06-02-2004 06:35:18
My 69 CK580 has the a set of hooks on the boom, too. This makes sense because you can adjust the angle of the boom by chosing the chain link that will be inserted into the hook. the chain is welded under the foot pedals as you have shown in the diagram. When the chains are not in use, I hook them up out of the way, so they cant get hung up on anything (like in tire chains, for example).
Dennis/Ohio
06-02-2004 03:46:57
Mike,
My 530 (but not CK) is very similiar. Hooks are welded on boom where you have the question mark. Chain weleded at the other end. Chains hang straight down when digging. Make the chains a little long. My garage door is only 10 ft high so I chain the boom lower when I'm going in and out of the garage. When my chains are hanging down, they are about six inches from the ground. They never have gotten in the way of anything? I guess you could weld the hooks on the hoe at both ends if you wanted to completely remove the chains.
Dennis.....
Mike Fallavollita
06-07-2004 10:01:06
 Re: Re: Transport chains on 530CK in reply to Dennis/Ohio, 06-02-2004 03:46:57
third party image
Well, here is a picture of what I did. It seems to work exactly as I had hoped. Thanks to everyone for the feedback.
-- Mike
