DC Case Starts but does not keep running?
sully
06-01-2004 09:33:53
I have a tractor that I would like to get running so that I can sell it. It starts and sounds ok , but after 15 seconds or so it stops running. It is getting fuel to the carb. but I dont dont know how to check if I am losing the spark or not feeding gas to the engine? Last year I had a similar problem but it would run for a longer period before it would die. Any information would really be appreciated!
denny
06-03-2004 21:31:08
 Re: DC Case Starts but does not keep running? in reply to sully, 06-01-2004 09:33:53
Might be interested in your dc, if I had more details. Eagle hitch? Power steering? Foot clutch? General condition? Location? Price? Pictures? Thanks. D.L.
Sully
06-06-2004 08:50:19
 Re: Re: DC Case Starts but does not keep running? in reply to denny, 06-03-2004 21:31:08
No eagle hitch, no power steering, hand clutch, general condition is good, located in Western Nebraska, TAG-5512939DC, $250
Bob From Wisconsin
06-01-2004 14:39:01
I had the same problem with my SC, rust in the gas tank. You might want to check that out.
Where are you located? Does the tractor have an eagle 3 point hitch and live hydraulics with a foot clutch? I would be interested if the price is right and you are near Wisconsin.
Thanks
Sully
06-03-2004 16:30:47
 Re: Re: DC Case Starts but does not keep running? in reply to Bob From Wisconsin, 06-01-2004 14:39:01
Thanks for responding! I dont know alot about tractors but this has a hand clutch and is in Western Nebraska.
Jeff In Ontario
06-01-2004 10:01:36
Could be a bad coil, usually if a coil is worn out, when it heats up it will only run for a few minutes, then conk out..just a thought ---JEff
C. Amick
06-01-2004 09:58:58
I wonder if it is getting enough gas to the carb? I suspect rust may the gas tank outlet partially blocked. Have you removed the fuel line from the carb and turned the gas on to see how much gas is flowing to it?
roy
06-01-2004 21:19:42
 Re: Re: DC Case Starts but does not keep running? in reply to C. Amick, 06-01-2004 09:58:58
I usually put a timing light on a spark plug and can tell if the ignition quits.
Disconnect the fuel line to the carb and see if you get continuous flow or it slows to a dribble.
