case 310B Backhoe/Frt Loader Rubber Tires
Tommy M
05-31-2004 18:53:24
No oil pressure. Tried new line and gage. Fear oil pump is gone. Maybe more. Runs great tho. Where can i find an oil pump?? Only numbers i can find on head is VT148 and on block is 10182. Thanks for any info.
Mike Johnston
05-31-2004 19:28:23
 Re: case 310B Backhoe/Frt Loader Rubber Tires in reply to Tommy M, 05-31-2004 18:53:24
third party image
Mine had no pressure when I got it, after not running for years. The relief valve in the pump body had stuck open somehow. After freeing it up, the pressure is now 14 lbs or so.
Drop the axle and pan and see whats going on. Its possible that the pick-up tube could have come off also. Not very likely that the pump would just completely quit working.
Mike Johnston
Tommy M
06-01-2004 02:27:57
 Re: Re: case 310B Backhoe/Frt Loader Rubber Tires in reply to Mike Johnston, 05-31-2004 19:28:23
Thanks Mike. Does the front end really have to be dropped?? Glad to know i'm not the only one to have one of these. Is there any suppliers out there for parts for these??
Mike Johnston
06-01-2004 07:09:46
 Re: Re: Re: case 310B Backhoe/Frt Loader Rubber T in reply to Tommy M, 06-01-2004 02:27:57
As far as I know, you will need to drop the axle on yours. I believe the tricycle version is the only one that you can drop the pan without removing anything. It really isn't much of a job to get the axle out of the way.
Most of my parts have come from salvage yards and from others that post here. The only thing that took a while to locate was the power steering assist cylinder.
Mine is a 210B without the back-hoe. Not sure what the differences are between a 210 & 310, but there aren't many. Post a photo if you have one. I'd like to see it.
Tommy M
06-01-2004 15:07:48
 Re: Re: Re: Re: case 310B Backhoe/Frt Loader Rubb in reply to Mike Johnston, 06-01-2004 07:09:46
Thanks again. Going to pull pan to check pick up first. In the process of trying locate an oil pump just in case. I'm trying to figure out how to post a pic on here. If this don't work i'll try again.
